Flashed OSSC with wrong firmware
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Flashed OSSC with wrong firmware
  • #25706
    ZeusPT
      Ok did something stupid, just updated OSSC firmware with the latest version but i used the aud.bin file by mistake instead of the normal .bin and my OSSC is the normal one, i tryed to install the correct one but can´t acess the menu with the remote, it´s just stuck on the inicial screen saying fw0.82aud. Any solution besides having to buy the audio board and tranform it in a internal audio OSSC one ?
      Thanks
      #25707
      ZeusPT
        ok just found out you can reprogram the remote by turning off and on the ossc while pressing the red button 1 on it. Updated again with the right file , if ou do the same mistake hope it helps.
        #25713
        Morpheus_79
          The remote control setup is described in the wiki:
          http://junkerhq.net/xrgb/index.php?title=OSSC#Remote_control_setup
          And afaik your problem had nothing to do with the aud- and non-aud-firmware. It’s simply a totally normal behavior for the OSSC to return to its standard ir codes after a firmware update:
          http://junkerhq.net/xrgb/index.php?title=OSSC_L336
          So: if your remote is programmed with compatible (but different) ir codes, after any new firmware-version you’ll have to configure your remote again.
