Gamecube D Terminal and OSSC
  • #21300
    zoopster
      Hi
      I have an NTSC-J Gamecube and was looking at buying the D-Terminal cable to connect to the OSSC. Would this work?
      Thanks
      John
      #21303
      ErebusMaligan
        You would also need a D-terminal to 3 component male RCA adapter. Many of these are marketed as adapters for cameras of various types. If you get this, then yes it will work fine plugged into AV2. This is what I was using on mine before I went to an HDMI adapter.
