Good enough quality for my RGB N64?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Good enough quality for my RGB N64?
  • #36896
    Gardner95x
      Hi guys,
      Recently got a RGB modded NTSC-J N64 here in the UK which has been converted to play PAL games, now I downloaded a profile online for a RGB N64 setup on my OSSC but am wondering if anyone thinks the quality is good enough?
      I have it running on a Samsung full HDTV and the OSSC says it’s on 313p/288p and the TV says it’s 720×576.
      I have 2 pictures showing my setup so can I have some feedback on it please?
      N64
      It’s definitely better than composite I used to use I’ll admit.
      Thanks
      Jack:)
      #36916
        Very difficult to tell just from digicam shots, you do need to change your TV into 4:3 mode though to stop stretching out the image.
