Help w/ Dialing in NES Play on ED64 Plus (N64)
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Help w/ Dialing in NES Play on ED64 Plus (N64)
  • #23669
    Anonymous
      I just got a ED64 Plus v3.0. I love it so far. I’m trying to dial in the OSSC when playing NES games via the N64 w/ ED64 Plus. I tried FBX’s optimization for the NES w/ NESRGB mod, and that doesn’t work for this particular configuration. Anybody got some good optimized settings for this configuration?
      If it helps, NES 240p test suite reports the following:
      cycles/line: 113.9
      Lines/frame: 262
      NMI scanline: 241
      It is all NTSC.
      Thanks in advance!
      #23670
        Graphics are probably pre-scaled to conform with N64 output (afaik N64 only outouts in 640 column mode). That probably means optimized mode will not look good anyway, because you’ll have interpolated pixels all over the place.
        #23673
        Anonymous
          I should have added that I have n64rgb mod with deblur. N64 optimized looks great. The same optimization doesnt work when playing nes games via the ed64 plus.
