horizontal interference lines in OSSC 1.6 and no sound
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support horizontal interference lines in OSSC 1.6 and no sound
  • #38236
    Virtualnate
      Hi all, so I own the OSSC 1.6 revision.
      My setup:
      PVM 1953MD
      gscartsw>kabeldirekt male scart to scart cable>OSSC>kabeldirekt HDMI cable (20ft)>HDMI TO DVI-I adapter into the Datapath E1s
      I’m using the Datapath software to capture everything. I get occasional green horizontal interference lines, like what madlittlepixel from YouTube gets
      https://www.youtube.com/watch?v=EyGnOuzmXTY&t=328s (check it out at the 2:26 mark)
      If there’s anything I’m doing wrong please let me know. It happens across all my SCART and component consoles (using the SHINYBOW SB-5470)
      THANKS IN ADVANCE!!
      #38245
      Anonymous
        This is weird! I have a similiar problem that I fixed in s-video capture, going into OBS and changing the resolution/fps type of capture device to custom and setting a different custom resolution. But I bet this is a problem with drivers of my internal s-video card or the card itself. So, check out for drivers and other stuff to use with the Datapath card. About no sound, there’s a tiny switch next to audio output in OSSC – check this and also check: RetroRGB
