How much lower will OSSC Pro Scaler Mode Latency get when it’s improved?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › How much lower will OSSC Pro Scaler Mode Latency get when it’s improved?
  • #71177
    spacetime66
      Hi, I’m wondering when Scaler mode latency is improved on the OSSC Pro will it only be modest at 60hz like only going from 18ms~ to 16.67~ or will be more significant?
      Thanks
      #71361
        It really depends on the scaling done. If vertical size is not significantly changed, then latency could be close to A-LM latency.
        #71393
        spacetime66
          <p>I’m mainly curious for things like 720p to 1080i/540p and scaling the image to correct overscan on Sony HD CRTs when low latency HDPT mode which can sometimes needs a weird resolution…</p>
          • This reply was modified 4 days, 4 hours ago by spacetime66.
