Hi!
I was working on an old 1970s ‘TV Game’ thing, trying to get composite-out from it.
I had it connected to my OSSC via my Koryuu. Seemed to work for an instant, then died.
From then on, I couldn’t get the Koryuu’s test pattern to appear on AV2 on my OSSC.
I thought I’d broken the Koryuu, but I still see its test pattern (albeit in mono) if I connect the G line from it directly to a TV’s composite input.
So it seems I’ve fried the AV2 input on my OSSC.
RGB SCART on AV1 and the VGA port still seem fine. Any tips on where I should poke on the board to figure out what I need to fix, or anyone done something similar and managed to fix it? Any advice welcome!
Cheers!
This topic was modified 3 years, 2 months ago by
Chris Platts.
Chris Platts.
