IR Remote working ?
  • #44500
    bascobug
      Just received my OSSC 1.6 (with official remote controler) yesterday, and trying to use it with an Amiga.
      I have a problem : It seems OSSC IR Receiver does not work.
      I try to start the remote setup procedure but when requested to enter 1 key and nothing happen when I press a button on the remote controler. I try also another working IR remote with no success.
      The green led of OSSC didn’t go out briefly when an IR remote code is sent.
      Let me know if there is something to do in this case ?
      Regards
      #44520
        The remote might have been switched accidentally to control another device. Press the TV button in the upper left corner to switch it back to control the OSSC.
        Hope it works. 🙂
