Jitter Master System and Mega Drive
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Jitter Master System and Mega Drive
Viewing 5 posts - 16 through 20 (of 20 total)
  • #16839
    wumbo64
      It is that cable and there isnt any mention of a sync stripper.
      I have changed alot of settings but nothing seems to help.
      Maybe its a combination of settings that need adjusting.
      Im going to try a different rgb cable today hopefully that helps
      #16842
      paulb_nl
        Does it happen in every lineX mode? Maybe try to tweak V.synclen in Advanced timing tweaker.
        #16845
        wumbo64
          I can only use 2x mode, i have tried changing the V.synclen but doesnt make a difference.
          I have also tried a different rgb cable but with the same result. So i can only assume its something the mega drive and mastersystem output that the ossc doesnt like
          #16846
          wumbo64
            it turns out its a strange issue the tv had with the mega drive/ master system being passed through the ossc.
            i set the ossc on my main tv and the issue wasnt there.
            I just need to get a good tv that supports everything.
            #16866
              Pretty rare for a TV not to work at 2x, that’s very unlucky.
