MVS and OSSC – No output
- This topic has 0 replies, 1 voice, and was last updated June 1, 2021 at 3:28 AM by .
Viewing 1 post (of 1 total)
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › MVS and OSSC – No output
I recently consolized an MVS MV1FS using a Stryder NTSC Encoder and XRGB pinout. I’m connecting to the OSSC using a passthrough scart cable from RGC and I’ve added a 470 ohm resistor on the sync line. (The encoder has 500 ohm pots for the rgb lines.)
I can get my device to sync steady (solid green light) using Line 1x and 3x only though. And regardless I still get no output no matter what screen I use. I’ve tried three different screens and two hdmi cables. (Yes, I can get the test pattern to show on all three.)
The OSSC reads 240p, 59.2hz so I assume it’s getting a signal from the MVS?
Does anybody have any idea what might be going on?
-Phil
