Hi, I have a PAL N64 with a RGB Advanced board (and no filter add-on), I’m using a SNES NTSC Csync cable (from RetroGamingCable uk).
It works fine on my PVM and on a random Samsung 1080p TV but I get a “no sync” on the ossc.
Am I missing something ?
From what I could tell, the filter add-on is more for some problematic capture cards and to make PAL SNES cables compatible, is this required to work on the OSSC ?
SOLUTION : Run a small wire between pin 3 and 7 (Csync and Luma)
I just installed another one on another N64 and I get the same results : ie. No Sync on OSSC
Also, both of them don’t work in line 2X mode on my TV (samsung 1080p), the screen is cut in half as if I was sending 31KHz to a 15KHz display. I’m not sure this issue is related though
