Need some help using my Extron CP 300 with the OSSC (no Sync)
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Need some help using my Extron CP 300 with the OSSC (no Sync)
  • #40867
    RetroVidya
      Hello all,
      I thought I did my research correctly but maybe I’m missing something.
      I have an Extron CP 300 (it says with ADSP) which for simplicities sake lets say has an SNES on input 1 (using a CSYNC scart).
      It’s using 2 outputs. One to my PVM, no issues. The other to my OSSC which yields no Sync.
      The OSSC works because I can directly connect the SNES to it.
      The Scart to BNC breakout cable (female) I bought for the Extron, which outs to the OSSC, is attenuated. What could I possibly be missing here? I thought the Extron would be able to output to the OSSC fine so long as the scart to bnc was attenuated.
      Thanks,
      #40878
        I use Extron Crosspoints in my setup and they work great with OSSC.
        Are you sure it’s a SCART output cable and not a SCART input cable you’re using to connect to OSSC?
        #40882
        RetroVidya
          Hello Bucko.
          I can see that it’s wired for PIN 20, which according to the documentation is Composite Input.
          I’ll just need to wire it to PIN 19 then I guess?
          #40890
          RetroVidya
            Wired to PIN 19 and now it works.
            #40891
            RetroVidya
              Audio needs to be re-wired from IN to Out as well.
              Pin 6 and 2 to 3 and 1 respectively.
