Neo Aes 3-5 Video Issue
- This topic has 0 replies, 1 voice, and was last updated November 16, 2026 at 1:26 PM by .
Viewing 1 post (of 1 total)
NewHome › Forums › CPS2 digital AV interface › Neo Aes 3-5 Video Issue
<p>Hey there,</p><p>I recently completed an install on a Neo AES 3-5 board. Unfortunately, i’m getting a strange picture issue. No matter what cable or tv I test HDMI on, the image has “scrolled” vertically (imagine cut in half then switch the pieces around, top and bottom vice versa). Changed the on screen menu clock setting and tried all the resolutions. Tried a few different power supplies. I did figure out, if you reset the console with the reset button, the picture moves down slightly with each reset. Enough resets and the image will be vertically centered as it should be.</p><p>Thought it may be a power issue, but i’m getting 5v at each of the tapped capacitors. Video works as it should through the original composite jack.</p><p>I did NOT use a coax cable for the C1 connection like the instructions suggested. Could this possibly cause such an issue?</p>
