Neo Geo Omega output cut off horizontally?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Neo Geo Omega output cut off horizontally?
  • #26350
    ClarkDV
      I am using a wega widescreen CRT to play all my games. It runs perfectly, but the left side is cut off horizontally as seen in picture. I’ve adjusted settings on the wega including service menu, and on the OSSC and can’t seem to get it. The Wega doesn’t support the 320×240 opt mode, only 4:3 standard. Any back porch or horizontal adjustments only seem to add gray to the right side, or cut off the left side even more. What should I do?cut off
      #26351
      ClarkDV
          Weird. If you have an Extron interface lying around with picture adjustment you could try that but otherwise I’m out of ideas.
