EDIT: Images don’t seem to be working, so have linked to images instead.
My completed barebones DIY assembly has an issue with AV1. Per the attached title screens for SMW (RGB modded SNES Mini) and Sonic 1 (Genesis) it appears that the green data is either not being received or just not processed.
Both consoles are using C-Sync cables from Retro Console Accessories, which work fine with the Framemeister.
Using the RGBS setting.
The third pic shows Wonderboy 3 (PAL SMS) through a HD Retrovision Component cable to AV2. Greens show up fine there so appears to be AV1 only which has the problem.
I’m off to buy a Logitech remote so I can dig around in the menus, but don’t think the issue is to do with settings. More likely to be something I’ve done wrong or missed in construction.
SMW Title
Sonic Title
WBIII
