No HDMI audio in Line x3, x4?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › No HDMI audio in Line x3, x4?
- This topic has 21 replies, 8 voices, and was last updated November 25, 2017 at 4:40 PM by
Flare.
September 28, 2017 at 2:52 AM #15487
@marqs – Great call! Thank you! I never would have even noticed that little switch had you not mentioned it.
September 28, 2017 at 8:03 PM #15507Just for the heck of it, I tried the sound suggestion Bonzo made a few times, but no such luck. Thank you for the suggestion though π I got lucky though for my streaming purposes. Even though my monitor doesn’t seem to pick up the HDMI audio in x3 or x4, my capture card (Avermedia HD C985) does. So that’s actually the more important part. Now I just use the 3.5mm jack for my speakers.
Also, seriously Bucko. The remote on this thing is GREAT! Whenever I used the XRGB remote I had to find like the perfect sweet spot to get a response from it and it was quite annoying having to hold my arm in the exact position every time I wanted to make changes or do testing. It would give me neck cramps. Now I can just casually point in its general direction and it’s no problem. Thanks for that!
September 28, 2017 at 8:34 PM #15509Don’t thank me thank Markus π We did have some issues with the remote a few firmware revisions back, but Markus fixed it.
September 29, 2017 at 1:50 AM #15519Well then, thank you Markus! I really appreciate the extra effort put in. Those little quality of life features are always nice and appreciated.
October 29, 2017 at 12:11 PM #16523I have the exact same sound issue with my modded PAL SNES, Marqs if you ever find out what to mod on the machine I will gladly make an additional fix.
By the way in x2 the picture is already terrific π
October 29, 2017 at 6:10 PM #16531I have the same issue, but I’ll add info on my setup. I’m also using an RGB modded SNES (via YPbPr + the analog input on the OSSC). I’m running the OSSC output into an HDMI switch, and the switch’s output into a splitter. Basically the idea is just to have a bunch of game consoles into the switch, which can then play on my monitor + be captured with my capture card. I initially blamed the switch/splitter for some issues, but found something interesting..
With my SNES, in Line 3x.. I get no audio from my monitor (BenQ XL2720Z), but I do get audio from my capture card (Startech USB3HDCAP, recorded via AmarecTV), simultaneously. Therefore, it seems the SNES output is correctly being mixed into the HDMI, and everything in the signal chain (switch, splitter) isn’t stripping the audio, and it’s just some quirk of how the display is handling that specific type of output when in >Line 2x mode?
I tested some other modes through the same display. Passthrough doesn’t display at all, out of range. Line 2x plays video and audio. Line 3x plays video but no audio. Line 4x also plays video but no audio, and also desyncs. Line 5x has no display. Video-wise, the monitor seems to handle Line 3x the best, with even aspect ratios being seamless.
I’ll also note for completeness that other devices through the same setup, which output at standard 720p/1080p, have no audio issues.
November 25, 2017 at 4:40 PM #17524Same issue here, I can’t get audio through my monitor (ASUSVX238) on 3x/4x, yet I can hear it on 2x. My capture card (pexhdcap60L) gets audio just fine though with 3x/4x. Was there ever a fix for it? I know I can use the 3.5mm output, but the convenience of hdmi is so good. This is just for SNES by the way. I haven’t had a chance to test ps1/2.
