No left audio
- This topic has 3 replies, 2 voices, and was last updated March 21, 2020 at 12:03 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › No left audio
Hello. I am only getting right channel audio over HDMI.
I’ve always used the mini jack output for audio so I do not know if this was from new.
I’d like to use the HDMI audio now.
If I set the OSSC to swap left/right it does swap to the left, so must be a bad joint somewhere?
Any advice on what I can try to fix this?
Chris.
Have you tried more than one SCART cable?
The audio works as expected through the 3.5mm jack.
Its just over HDMI that i only get the right channel.
Since I can swap the audio in the OSSC settings, I guess the left channel isn’t getting to wherever it needs to go.
@BuckoA51 Any advice on this?
To be very clear I can get sounds from both channels over HDMI, just not at the same time. It seems like the console audio left channel isn’t making its way to where it needs to go. I do not think its a HDMI issue because I can swap the channels in the OSSC settings and that gives me left audio only instead of right only. I know it’s not my consoles or my cables and the 3.5mm audio jack on the OSSC outputs perfectly both left and right.
Thanks,
Chris
