No signal after hot-plugging HDMI to VGA adapter
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › No signal after hot-plugging HDMI to VGA adapter
  • #51284
    Vrenna
      Hello,
      Yesterday while connecting some 3.5mm audio cables I have removed a HDMI to VGA adapter while the OSSC was still actively running a PS2 in 480p i.e. hot-swapped the adapter. Ever since that happened there’s no signal from any of the inputs in any of the modes; the OSSC detects the consoles and is glowing green, but there’s no output on any of my monitors. Have I fried the HDMI slot? Is there anything I can do to fix it?
      #51299
        Unfortunately yes you’ve probably damaged it. You may need to unsolder the HDMI transmitter and solder another one in though it could be any number of components that have failed.
