Noise flowing up the screen..
Viewing 2 posts - 16 through 17 (of 17 total)
  • #50486
      Thank you for that. Finding and eliminating powerline noise is frustrating for sure, especially when it gets down to removing devices you actually want or need in your setup.
      #50488
      Reezo
        You’re most welcome. Hopefully it will help others as it was kinda hard to find a thread that had my exact same findings.. given the nature of the beast, things are so erratic that it’s hard to get a perfect match. But this thread gave me hope.
        I am going to sit down, clean the nice wooden cabinet the whole rig sits on and try and remove unnecessary stuff to see what’s going on..
        On a side, I was thinking that making an RGB to SCART cable with a VGA cable, would be pretty good.. there are all the wires that we need, there is a global insulation, plus single insulation for each wire, plus each wire has an internal naked ground filament.. this is pretty good and it’s so hard to find properly-shielded cables in SCART land.. my soldering skills aren’t bad. I might keep it in mind if I find out the cable’s the reason..
