OSSC 1.6 Playstation 1 issue!!! please help!!!
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC 1.6 Playstation 1 issue!!! please help!!!
  • #17676
    MCLiLBas
      Hello,
      I have received my OSSC 1.6, and I am happy with it! However, I have an issue with Playstation 1, For example, When I play Silent Hill 1, whenever I open the map or go to the inventory, the screen goes black, sound disappears and the OSSC 1.6 blinks red for 3-4 seconds then back to normal, screen comes back again with sound. It is basically like if you’re changing the input of a TV as an example!
      I am using a Csync PS1 Scart Cable from retrogamingcables
      On a PC Monitor ( Asus ) I have tried all x2 x3 x4 x5, the same thing happens!
      Help please! it’s annoying!
      #17677
      darkstrider2
        I believe Silent Hill is one of those games like Chrono Cross, 480i menu/maps, and 240p gameplay.
        OSSC is handling a switch in video signal. So this is actually normal for upscalers, same thing happens with the Framemeister, but I believe Framemeister takes longer to do 240p->480i transitions and back.
        #17679
        MCLiLBas
          Thank you for your explanation! But I have a cheap upscaler that doesn’t have this issue when playing Silent Hill at all! Why is that? Any idea?
          Is there a fix to this issue to work with the OSSC 1.6 without this annoying transition?
          Appreciate the help!!!
          #17680
            The cheap upscaler probably frameconverts every input type to a standard framerate (as well as interpreting 240p input as 480i from the beginning), so the display does not drop image.
            3-4 seconds sounds unusually long though, in my experience OSSC resyncs between interlaced and progressive modes should not take more than half a second or so. The main culprit of delay is more likely your screen.
            It could be that transitions take less time if you have your 240p mode and 480i mode set to the same output, ie. Lx2 240p to 480p and bob-deinterlace 480i to 480p. However, the framerate still changes slightly so your display will still drop the picture for a moment.
            #17683
            MCLiLBas
              Thank you guys!!!
              #17711
                Yeah those cheap upscalers convert to 59.94, this causes stuttering/juddering in motion. Still, you might prefer that to screen blanking, some of those cheap scalers have HDMI input too, so you could try that.
                #17828
                eric90000
                  What is the current best way to deal with the 240p > 480i transition dropout? Only thing I can think of is use a CRT 🙁
                  #17831
                  darkstrider2
                    Best way? Perhaps for PS1 classics, probably straight up PS1 emulation via PS3. Not bad price to pay if you only pay for PS1 Classics that have this issue (e.g: Chrono Chross, Silent Hill).
                    #17832
                      That is the only way to deal with it 100%, sadly.
                      #17833
                      eric90000
                        Ahh yes, I never really considered playing the offending titles on the PS3….I have the luxury of a PSIO you see, and the PS1 looks amaze on the OSSC. I might just use PS3! thanks
