OSSC and Acorn Archimedes A440/1
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC and Acorn Archimedes A440/1
  • #66885
    craig_read
      I have an issue when using the OSSC with my Archimedes A440/1.  I have the OSSC connected to the Archimedes via a VGA to Scart cable, with the SCART going to the OSSC.  The OSSC is then connected to my monitor via HDMI.
      For the most part the OSSC works fine, and the monitor displays the computer output, however, and sadly not too infrequently, the screen will blank for a few seconds and then come back.  I am not sure why this is happening or what to do about it, is there a setting in the OSSC that I can try to change to prevent this?
      Thanks
      Craig
      #66886
      craig_read
        The OSSC is v1.6 using 0.90a firmware
        #66888
        Mark Jaques
          Yeah – I had similar problems. I fixed it with a GBS-Control! 🙂
          #66889
          craig_read
            So basically replace the unit with something else? 🙁
            #66897
              Analog sync Vth setting is at least worth trying out. I’d also try direct VGA connection.
