OSSC and Line2X Problem?
  • #23103
    Alan
      Hello,
      I bought this unit specifically for it’s Line2X capabilities, however I am not sure if something is wrong with it as when things are set to Passtruh things seem normal, however whenever I change to Line2X no matter which console I am using, everything becomes weird looking?
      I took some comparison screenshots on my Wii (please click on the pictures to zoom in),
      Line2X:
      View post on imgur.com
      Passtruh:
      Line2X:
      Passtruh:
      Not even mere text seem to be spared:
      Line2X:
      Passtruh:
      Tried The Legend of Zelda Twilight Princess on GameCube at 480p using the Official Component Cables, used Line2X with FireBrandX settings suggested settings here: http://www.firebrandx.com/OSSC/OSSC%20-%20Nintendo%20Gamecube%20480p%20Optimal%20Timing.txt
      And this is what I got:
      Is this normal!?
      #23112
      Deleted User
        where is the problem? Passthru looks washed out. Is it the more pixelated image that you don’t like? Did you try the “Allow upsample2x” option?
        #23113
          Allow upsample2x will definitely take some of the jagginess away, but if you simply don’t like that look then that mode is probably not for you.
          #23116
          Alan
            Thank you, I’ll try with upsample2X, but do you guys have any timing settings I could use also for Wii? Or at the very least use as pointers at least? Like sampling phase and such?
            #23119
              The FirebrandX settings you linked to should be fine.
              #23120
              Alan
                The FireBrandX settings don’t cover the Wii though?
                #23121
                  Wii outputs standard 480p, samplerate is 858. That’s the same as Gamecube settings.
                  Sampling phase will always vary so you just need to test what works for you.
                  #23122
                  Alan
                    I see, thank you very much.
