OSSC and PAL Gamecube sync issue
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC and PAL Gamecube sync issue
  • #69423
    Munkeh
      Just got myself an OSSC 1.8 along with Packapunch Pro Scart Cable from Retrogamingcables.co.uk to go with Dol-001 Gamecube.
      It doesn’t sync at all – cycles through resolutions with no picture on screen the moment I select AV1 and RGBS.
      STUPIDLY I didn’t have a Mini SD Card ready to update the system, so I’m wondering if it might be a firmware issue – or something else?
      I’m trying to get it working on a 2017 LG OLED.
      Any tips would be gratefully received as I’m a bit lost.
      #69428
        You should first try adjusting Sync options -> Analog sync Vth.
        #69453
          Is it a PAL Gamecube? Only PAL Gamecubes can output RGB. Even so you’re better off using component as this unlocks the ability to use 480p, which works much better on modern displays.
