OSSC Firmware build fails on linker
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – DIY & Repair Support › OSSC Firmware build fails on linker
  • #26155
    renegadeandy
      Hi all.
      I am setting up a new dev environment – windows 10, and am using the Eclipse included with Quartus.
      I believe the compile was successful but we then hit the linker, which is failing I think.
      I installed the riscv-unknown-gcc by compiling from source with https://github.com/riscv/riscv-gnu-toolchain and MinGW32.
      The build process fails with the following:
      (Can’t paste stack trace in here as i get an HTTP 403 from WordFence :/)
      https://gist.github.com/renegadeandy/48d019859797bb143f576903de3aaf75
      Can anyone help shed some light on what may be going wrong here?
      #26160
        Did you configure the toolchain with correct arch and abi options?
        ./configure --prefix=/opt/riscv --with-arch=rv32emc --with-abi=ilp32e
        #26161
        renegadeandy
          Almost certainly not! Trying so now!
          #26162
            You could always put stack traces on one of any number of pastebin solutions and post a link here.
