[SOLVED] OSSC Line 5x Sega Mega Drive PAL Help with Settings
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › [SOLVED] OSSC Line 5x Sega Mega Drive PAL Help with Settings
Viewing 1 post (of 1 total)
  • #49323
    Reggie Sunderland
      Nevermind, I decided to try on my newer secondary ultrawide monitor and it works perfect.
      I’ve got a OSSC about two weeks ago and I took my time to familiarize myself with every setting on it, I’ve managed to configured it perfect pixel rate and sync on 256×240 optim. with perfect 4:3 aspect ratio and 320×240 optim. but the aspect ratio is a bit stretched which I believe it’s the monitor’s fault.
      The monitor also supports Line 5x but the image is squished as shown in this picture: https://i.imgur.com/met4WM1.jpg , I have tried messing with the H.samplerate, etc but to no avail I can’t get it to stretch and I’m wondering if it’s also the monitor’s fault, especially for being ultrawide, the image does stretch if I set the monitor picture from Original to Wide but then it’s way too stretched, any help is appreciated.
      Monitor: LG 29UM59
      Mega Drive: Model 1 V6.8
      Connection to OSSC type: AV to Component from RGC
      And a picture of the OSSC display if needed: https://i.imgur.com/LGfmOXS.jpg
