OSSC LITTLE TEST / 240P
Viewing 3 posts - 16 through 18 (of 18 total)
  • #8392
    afangus
      I will re test with X2 (saturn + av3) – and tell you what’s going on
      for now in av1 :
      Saturn :
      splendid
      Xbox (av2 yuv 480p):
      Next test my MVS mv1c (see there are troubles with some slot…)
      #8512
      afangus
        Okay
        So tested the saturn ntsc j with X2 same problem over av3 rgbhv or rgbs (via sync strike) black screen with 480i contents
        The sync strike via av1 works perfectly well
        Tested my MVS slot MV1C works like a charm, even more beautiful than the neogeo :p (directly hooked to OSSC in av1)
        After more test over av1 it seems that every pal signals I’ve got works fine in X3 with my HC Onkyo TX NR 808
        #8553
        afangus
          SFC (via sync strike av1) :
