OSSC Output to CRT
  • #54466
    Mark Jaques
      Hi, my OSSC is hooked up to an Amiga A1200. I am outputting to a VGA CRT at 50Hz, which makes sense – and needless to say the picture quality is fine but it does flicker a little so would like to know, if possible, if I can force the output to 60Hz from the OSSC?
      #54467
        You’re lucky your VGA monitor even supports that. No, OSSC cannot convert frame rate. Such a conversion would probably not be desirable anyway as it would make the image stutter.
        #54468
        Mark Jaques
          Oh dear. Well, guess I’ll be using an Indivision then. Thanks for the prompt response.
          #54481
            I’d recommend sticking to 50hz if your monitor supports it, you can’t convert to 60hz without introducing judder.
