OSSC Pro Extra AV Out – issue with Commodore 1702 monitor
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro Extra AV Out – issue with Commodore 1702 monitor
  • #71398
    jeff
      Hi there,
      I’m experiencing an issue with the OSSC Pro’s Extra AV Out when connected to a Commodore 1702 CRT monitor. The image repeatedly switches between a good picture and a black screen at regular ~1 second intervals. However, the same setup works fine for my JVC TM-H150CG CRT with S-video.
      Current hardware and configuration:
      OSSC Pro with Extra AV Out (Composite/S-Video), v0.83 firmware, Commodore 1702 CRT, connected to rear luma/chroma inputs using S-Video.
      Windows 11 computer connected to the OSSC Pro’s AV4 HDMI input.
      HDMI input: 640×480 at ~60 Hz
      OSSC operating mode: Scaler
      Output type: CRT
      CRT output mode: 240p
      Scaling algorithm: Nearest
      Extra AV Out: S-video+CVBS, NTSC
      Framelock: On, 1×
      CSync combiner: Type B (XNOR+)
      I’ve tried the following for troubleshooting:
      Tested both 240p and 480i output modes which gave me similar intermittent blackouts. 240p has ~1 sec interval and 480i has ~1.5 to 2 sec interval.
      Tested Framelock On and Off (60 Hz) – no improvement.
      Changed CSync combiner between Type A (AND) and Type B (XNOR+) – no improvement.
      Tested the OSSC Pro’s internal test patterns to rule out computer or HDMI source issue and the issue persists with test patterns.
      Tested composite output from the Extra AV Out to the 1702’s front RCA video input instead of the rear luma/chroma inputs and it has the same issue.
      I’m wondering if this may be related to the sync timing, signal levels, or another characteristic of the Extra AV Out’s composite/S-Video output that the Commodore 1702 isn’t handling well?
      Are there any additional OSSC Pro settings I should look at, or any known compatibility issues with the Commodore 1702?
      Any suggestions would be appreciated. Thank you.
      • This topic was modified 6 hours, 36 minutes ago by jeff.
      • This topic was modified 6 hours, 31 minutes ago by jeff.
      #71402
        Seems you’ve done all the troubleshooting I would have, and still issues that’s a shame, those little Commodore monitors are very nostalgic to me.
        If it’s the test pattern it has to be an incompatibility with the OSSC Pro itself. The 1702 is working fine with other sources, correct? Have you tried composite too?
