OSSC Pro – Fan and Fan filtering
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro – Fan and Fan filtering
Viewing 1 post (of 1 total)
  • #66884
    Leminur
      Hey Folks.
      I got myself the Noctua – Nf-a4x10 5v fan as recommended for the OSSC Pro, given that my place usually gets hot at this time of the year.
      I’ve done some research, and it seems like folks prefer to push in some cold air rather than pulling the hot air away. I am not sure if that is optimal given that the hot air always goes up, but I don’t have a way to test the thermal part. So my first question is, what is the best way to use the fan?
      Secondly, my apartment is being bombarded with dust due to the road optimizations happening just next to me, as well as other apartments undergoing renovations. I need to constantly clean things up. If I use a fan to push cold air into the OSSC Pro, I think it could push so much dust/dirt inside. Do you recommend using a filter to decrease the dust inside the OSSC? If so, which one? I have found some nylon ones, but they seem to be quite thick, and I am not sure if we have enough space inside.
      • This topic was modified 1 year, 3 months ago by Leminur.
