OSSC Pro firmware v0.81
- This topic has 19 replies, 8 voices, and was last updated April 3, 2026 at 5:47 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro firmware v0.81
I finally figured this out. Sampling phase needed adjustment. 0.81 working for me for Lumacode now.
Still struggling with MCR games though. Spy Hunter is perfect on 0.78 but super jittery on 0.79 and higher.
Ah I see. It seems to forget not only clock phase but its auto clock phase is also different. It also forgets the active pixels. If I manually update both of those (removing it from auto) it works again.
Hello,
this update was great, the input lag is now very small and every game is well playable!
But i missed a line-dropping mode for 1080p to 480i, so i can play Nintendo Switch 2 games on my CRT! Maybe the reason is, that is not a integer multiply, but 240p also wasn’t and this was implemented…
I actually used the scaler-mode, but maybe the line-dropping mode could be more deserve a more brilliant picture!
Thank you, if you support also a 480i mode in line-dropping for 1080p sources, so i have not the scaler artefacts!
Bye!
I’m not sure if that would be very useful in general since decimating into 540p and excluding 60 lines (plus CRT overscan) crops quite a bit content. It’d make sense only for sources that have ~900 lines of active content within 1080p.
Hello,
Bye!
