OSSC Pro firmware v0.82
Viewing 15 posts - 1 through 15 (of 17 total)
  • #69512
      Firmware version 0.82 has been released:
      * UI improvements
      ** character OLED contrast & timeout options
      ** improved profile cross-compatibility
      ** custom remote keys
      ** display EDID extract
      * Preset updates
      ** New 288p A-LM sampling presets
      ** Improved GBI Line3x Generic P-LM preset
      ** Added alternative 1080p100 presets
      * Lumacode support finalized
      * Support for updated Extra AV out expansion
      * Added Mono audio ADC option
      * Fixed BFI for interlaced sources
      * Improved XNOR csync combiner
      * SCL aspect adjustment added for optimized sampling presets
      Download link
      Update instructions
      Note: The following settings have been updated, thus their changes saved using previous firmware versions are not loaded from existing profiles:
      * A-LM 288p proc (due to new presets)
      * Audio options (due to new mono ADC option)
      * Extra AV out mode (due to new output modes)
      * Legacy AV options (due to range fix)
      * Csync combiner (due to new default value)
      #69513
      J5
        Thank you Marqs!
        #69514
        aotta
          just updated, this solved issue in vic20 lumacode i had with 0.81 FW, thank you!
          #69520
          osscboy
            Awesome!
            #69563
            tyro_2004_2004
              It updated Perfectly and it’s Working Great for the Sega Saturn. Thank you So Much Brother.
              #69570
              Tsukiko
                Thank you <3
                #69588
                vess
                  Hi marqs,
                  I’m using OSSC Pro (fw 0.82) with 480i sources in scaler mode at ×2 Hz (120 Hz output). I noticed that your implementation of BFI for interlaced sources does not produce visible flicker, even though BFI is active. I’d like to ask a few clarifications:
                  How is BFI implemented for 480i @ ×2 Hz internally?
                  Specifically:
                  After how many source frames do you insert the black frame?
                  Is it 1 frame on / 1 frame black, or a different cadence for interlaced?
                  When I enable BFI, the image does not look darker at all.
                  On my display (LCD/OLED), typical BFI clearly reduces brightness, but here it’s almost unnoticeable.
                  Is this expected with your interlaced BFI logic?
                  Could it be because BFI is applied only to certain fields or blended in a way that reduces flicker without heavy dimming?
                  How can I verify that BFI is actually active?
                  Are there any telltale signs (e.g., flicker pattern, motion clarity, brightness behavior, or an internal counter/LED indicator) I can use to confirm BFI is working as intended?
                  #69613
                  Kekstier
                    Stunning Update… wow… very impressive! Thank you!
                    I also have a new idea for line-dropping… in this version, you can only 480p content convert in lm-a to 720 x 480i… so of course i set my emulating mini pc to 720 x 480p…. there is possible to doesn’t fix the horizontal “cols” and send only 480i like 240p mode … so i can send a “genuine” 640 x 480p to my ossc pro?!
                    This would be very nice, but it’s not a duty, i have yet a very brilliant picture!
                    #69629
                      @vess: BFI operates on frames of deinterlaced 480i so the end result should have same amount of dim/flicker as with equivalent 480p source. You can control the insertion ratio with “BFI for duplicated frames” setting, but obviously going beyond 1 only works for 180Hz, 240Hz etc. output.
                      #70004
                        @marqs Thank you so much for adding the aspect ratio adjustment to scaler mode! It’s great being able to adjust it on the fly. 🙂
                        #70023
                        cdreed3000
                          I’m very excited for the updated Extra AV out expansion. When can we expect to be able to purchase it?
                          #70091
                          Jamie Shaw
                            Is an update required to the Profile Editor required for 0.82, or does 0.81 cover this release?
                            #70109
                              @cdreed3000 there is a small pilot batch currently in making, and a larger one should follow soon after if everything is OK with it.
                              @Jamie-Shaw
                              it covers it except the settings listed in first post
                              #70174
                              EchoEngine
                                If you don’t mind me asking what has changed with the updated Extra AV out board?
                                #70254
                                valeyard
                                  Something weird happens with my Panasonic Plasma when I update to 0.82.
                                  Upscaling or line multiplying to 720p works, but 1080p causes the screen to glitch out.
                                  I’m not sure what setting could be disagreeing with a TV from 2012. Downgrading to 0.81 fixed everything.
                                  Correction: It’s just the scalar. The display timings seem off. I’ve tried other settings, but 1080p60 isn’t working for me still.
                                  • This reply was modified 3 months, 2 weeks ago by valeyard.
