OSSC Pro firmware v0.83
  • #70273
      Firmware version 0.83 has been released:
      * Fixed 1080p SCL preset selection of previous fw
      * Improved Extra AV analog audio output flexibility
      ** support additional source sampling rates
      ** support conversion from SPDIF LPCM audio
      ** add gain control option
      * Added basic JTAG UART serial commands
      * Fixed border garbage on very low-res DV1 sources
      Download link
      Update instructions
      #70948
      J5
        @marqs Can you give more info about the “Basic JTAG UART serial commands” that were added? Is this like power on and power off; recalling presets Internal/SD via 3rd party control? Can you tell me pinout, baud rate, and command strings if so?
        Thank you!
        • This reply was modified 3 weeks, 5 days ago by J5.
        #70967
          The commands are listed here. It’s standard USB Blaster pinout / protocol where you don’t need to set baud rate. There are also developments for USB CDC-ACM dongles/boards which will be part of next fw
