OSSC Pro & Legacy AV card horizontal green lines
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro & Legacy AV card horizontal green lines
  • #70723
    onthewaveagain
      Have noticed that a horizontal green line pops up from time to time at a random location when using the Legacy AV card with my OSSC pro.
      This happens with both S-Video and composite sources. Have the latest version of the firmware.
      I bought the extension card 2 months ago. It is in an 3d printed enclosure directly plugged to the OSSC. I am using the OSSC standard PSU and I have tried with a 5V 4Amp with same issue.
      Happens at 6x and passthrough in ALM , have not tried other modes.
      Any idea?
      #70830
        Not something I’ve come across, have you noticed it across multiple displays?
        #70836
        onthewaveagain
          I have not tried on a different screen. However, I have tried to feed the morph4k with same signals on the same screen and I do not see these lines. I also get the same when I use the ossc as a digitiser in combination with the morph hence I suspect the problem is with the expansion card.
          I will try to capture the issue.
          #70865
          onthewaveagain
            It seems the adapter was not plugged all the way in. I did not get those artefacts anymore.
