Hi, I was wondering if it would be possible to add Line Drop, Interlaced and Line Doubling options to Advanced Display Timings in the Output settings menu on the OSSC Pro so you can replicate what the OSSC Pro does for 1080p to 1080i and 540p for Arbitrary Resolutions like say 1024x768p120hz to 1024x768i60hz
I’d figure if this is possible these option would be set to Auto by default and then when changed they would override what A-LM and Scaler is set to for that mode .
Also there seems to be modes that don’t show up in Advanced Display Timings so I can’t edit them and would like them to show up so I can
also it would be awesome if it would be possible to use the number buttons on the remote to enter Advanced Display Timings values considering how slow only using the arrow button can be
If you eventually implement any of this it would very appreciated.
