OSSC pro not saving settings
  • #70956
    kdog332
      My first day using this thing so apologies if I’m missing something obvious…
      So I get all my video settings dialed in how I want, then I go into into the Settings menu and make some changes, most notably changing the text highlight color to Red, set the fan speed to 30%, and changing how quickly the LED screen shuts off.
      I save the profile on the SD card to slot 0. Turn the OSSC off. When I turn the unit back on and load SD card profile slot 0,  I get the “104/104 items loaded”, my video settings all appear to be correct, but the actual Settings menu is unchanged. Text color remain yellow, fan speed still at 0%, etc.
      What am I doing wrong here?
      #70957
      kdog332
        I did update to the latest firmware when first got it set up btw
        #70965
          The options under “Settings” menu are saved separately into a common slot/file when any profile is saved. During power-up settings from internal flash are always loaded even if you have SD inserted with settings.bin. You thus need to save any profile into internal flash to get them stored.
          #70972
          kdog332
            That did the trick, thanks!
            #71002
            J5
              @marqs is it possible to have the profile store all settings? Extra AV Output settings as well as input, output, scaler settings and recall them when the profile is selected? I think most settings are saved but seems some are not. I ask because I have two different displays connected to the Extra Out. I have the output going into a Extron Crosspoint switcher and those outputs feeding either a VGA monitor or a CRT TV. Both need very different settings. I have each working great, but changing from one to the other by simply choosing a Profile load (Im using Internal) doesnt seem to change over everything. I can test more and give specifics if you like.    Thank you
              #71003
                All of the items listed above should be part of the profile structure. Let me know specifically which settings are not saved so I can look into it.
