OSSC Pro: PAL S-Video chroma issue fixed by toggling CSync comb B->A->B
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro: PAL S-Video chroma issue fixed by toggling CSync comb B->A->B
Viewing 1 post (of 1 total)
  • #71340
    corrosif
      <p>Hello,</p><p>I’m experiencing an intermittent PAL chroma instability issue with the OSSC Pro’s S-Video output.</p><p>Hardware and configuration:</p><p>- OSSC Pro running firmware v0.83<br />- Extra AV Out expansion board v1.3 (fully populated version)<br />- Output mode: S-Video + CVBS + RGBS<br />- CVBS/S-Video format: PAL<br />- Display: Sony BVM-20E1E fitted with a BKM-25P PAL decoder board<br />- BKM-25P setting: PAL-D (default). I also tried PAL-S, but this made no difference to the initial issue.</p><p>The S-Video cable is known to be good: the same cable produces a perfectly stable picture when used with my PAL C64 on the same BVM.</p><p>Observed issue:</p><p>After powering on or rebooting the OSSC Pro, the PAL S-Video output initially exhibits unstable colors:<br />- Colors periodically shift (for example, blue turns purple).<br />- The picture occasionally switches to black and white.</p><p>I have found a very consistent way to restore normal operation:<br />- CSync combiner is initially set to Type B (XNOR+), which is my usual setting.<br />- Switching to Type A (AND) does not resolve the issue.<br />- Switching back to Type B (XNOR+) immediately restores perfectly stable colors.</p><p>This behavior is reproducible after every OSSC Pro reboot.<br />I wonder whether this could be related to the initialization or reconfiguration of the CSync combiner, and whether this might affect the sync signal supplied to the S-Video encoder.<br />Sony BVM monitors are known to be quite sensitive to sync signal characteristics and levels, so I thought this might be relevant.<br />Has anyone encountered something similar, or could this point to an initialization issue in the OSSC Pro firmware?</p><p>Thanks!</p>
      • This topic was modified 3 hours, 17 minutes ago by corrosif.
      • This topic was modified 3 hours, 14 minutes ago by corrosif.
      • This topic was modified 3 hours, 9 minutes ago by corrosif.
