OSSC Pro: Signal Loss during Scaler Mode despite Frame Lock Off??? Help please!
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC Pro: Signal Loss during Scaler Mode despite Frame Lock Off??? Help please!
  • #63302
    Jojo Royce
      Hi all,
      I just recently got my OSSC Pro and was testing it practically all day. I’m liking it a lot so far on first impressions but I discovered a slight problem.
      From what I understand from the manual, the Wiki, and Wobbling Pixels’ in depth video about it, turning off Scaler mode’s framelock is supposed to prevent signal loss at the cost of increasing input latency. I have turned it off but it seems to still be losing signal.
      What I’m finding is that it’s handling resolution swaps about the same as both the Line Multiplier modes. I have no idea why, if it’s just the current way things are, or if I did something wrong. It seems to happen regardless of what off settings I use regarding framelock off. Source Hz, 60hz, whatever.
      I have a recording here that was captured from my EVGA XR1 Lite capture card showing it in Sonic 2. I tested it out with my Model 2 JP SEGA Saturn as well to see if it persisted elsewhere and it was unfortunately confirmed to not just be my Genesis. The results are the same regardless if I use my capture card or directly input it into my monitor. I have yet to test it on any TV in my home to see if the problem is exclusive to my monitor.
      Here is everything I used and I hope I had enough time for anyone to scrub through the video and see my settings. I am using the included PSU that came with it when I bought it and my OSSC Pro was updated to the latest firmware at the time of recording this clip. Any and all help is appreciated. Thank you!
      EVGA XR1 Lite Capture Card
      Dell S2721DGF Monitor
      SEGA Genesis Model 1 with “High Definition Graphics” label (unknown motherboard VA#)
      Insurrection Industries SCART cable for Genesis Model 1
      • This topic was modified 10 months, 1 week ago by Jojo Royce. Reason: First post and title wasn't clear enough about problem. Deep apologies
      #63303
        You need to disable frame lock. Set it to Off (50Hz) for PAL or Off (60Hz) for NTSC.
        #63304
        Jojo Royce
          I did, I thought I mentioned that in the first post but it seems I didn’t. Oops, I forgot to mention it, very sorry. ^^”
          You can see at 23 seconds in to the video that I set the framelock to Off (60 hz), but the problem is still occurring. It seems to latch on to the signal at first before immediately then dropping it.
          #63308
          Jojo Royce
            Edited the post and title so it’s more clear. Apologies, I was a bit tired and didn’t pay attention before posting. Continued help and support is appreciated, thanks!!
            #63315
              Are you using non-integer scale and auto aspect ratio?
              #63316
              Jojo Royce
                @marqs I have the scaling algorithm set to Integer (Overscan) and Aspect Ratio set to 4:3.
                #63317
                  Try selecting another scaling algo, integer is currently not guaranteed to produce non-interrupted switching.
                  #63318
                  Jojo Royce
                    @marqs Yep, as soon as I swapped to Nearest, the switching is now instantaneous. Since you said “currently”, will this be possibly addressed in a future firmware update? Also thank you for the assistance!
