OSSC Pro: some questions
- This topic has 16 replies, 6 voices, and was last updated June 5, 2021 at 1:37 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro: some questions
BetaGamma are based in Greece so would be a lot cheaper for you than sending to the UK after taxes etc if you’re based in Italy.
ah ok, thank you for you feedback. Well, I will evaluate if mod it with the RGB of buy Koryuu, more or less the cost is the same. Thank you again 🙂
