OSSC Pro sync issue with HDFury 3 in CRT output mode
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro sync issue with HDFury 3 in CRT output mode
  • #69119
    ackmangogo
      I’m encountering a sync issue when using the OSSC Pro in Scaler mode together with an HDFury 3.
      Setup:
      Output connected to HDFury 3
      Analog display connected to HDFury (via VGA / component)
      Issue:
      When selecting CRT output mode on the OSSC Pro, the display loses sync (no signal / unstable image).
      However, when switching the OSSC Pro to DFP output mode, the signal is stable and works correctly through the same HDFury 3 setup.
      Additional notes:
      Same cables and hardware are used in both cases
      Only the OSSC Pro output mode is changed
      HDFury 3 DIP settings remain unchanged
      Sync loss occurs immediately when switching to CRT mode
      #69120
        What signal are you processing through the OSSC Pro, or is it happening just with the test pattern?
        #69125
          Also, which CRT output mode you have selected?
          #69129
          ackmangogo
            From xbox360 and TV box, both tested from 480p and 720p.
            Source -> ossc pro hdmi in -> hdfury3(component) -> bvm d20
            A-LM output 480i and 480p works. 240p lost sync.
            Scaler mode output:
            DFP: 480p and 720p works.
            CRT: tried 240p, 480i, 480p, lost sync.
            #69130
              Maybe HDFury3 does not support the CRT modes which have high horizontal rate.
              #69164
              Steve
                I use a similar setup and my HDFury3 seems to cope just fine with whatever the OSSC Pro sends to it. I have the OSSC Pro feeding it generally 480i output which then goes from the HDFury3 into my PVM. I can try and remember to confirm what the DIP settings are on my HDF3 in case they matter if you’d like but I generally find it to be rock solid.
                #69301
                  Just tested and no issue here with HD Fury 3 and Mitsubishi Megaview, with an Xbox Series S and OSSC Pro in adaptive line multiplier mode and scaler mode (CRT) downscaling from 720p to 240p. Using RGB output rather than component though.
