OSSC Pro Uart
- This topic has 3 replies, 2 voices, and was last updated July 6, 2026 at 3:26 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro Uart
Hi I was wondering if anything has changed with OSSC Pro uart – is it possible to select profiles over uart via either jtag or usb? If so is it documented anywhere?
Anyone know? I saw marqs posted that it was a feature he planned to add in the future, but that was couple years back so I was hoping maybe it would be possible to select profiles from the jtag hart or uart over usb by now.
Unfortunately there has been no volunteers to start working on the feature over these years. This was recently also brought up elsewhere and I promised to add basic support for input selection and profile loading in near future. Somebody less overloaded can then expand support further if necessary.
This has been now implemented for both Classic and Pro, with latter having additional support for power up/down of the unit and enable/disable of IR remote control. The functionality will be part of next respective firmware for both. USB Blaster or suitable clone is needed for accessing the UART.
