Ossc Problem
Viewing 12 posts - 16 through 27 (of 27 total)
  • #23778
    Steo
      Are you using it on a strip or plugged directly into the mains? I have actually had that same problem on cheap component cables even hooked directly to the TV in the past where the TV would just lose sync.
      I was having the same issue as you on a Samsung TV before but then it was just a bad power supply because they had none when I bought my OSSC and I was using another one.
      #23782
      Vincenzo213
        sometimes i think the problem is rgb cables, car my consoles with official cables (gc dreamcast snes). do I have to buy new cables?
        #23784
        Vincenzo213
          I spoke too fast … no sync snes at the moment …
          #23786
          Vincenzo213
            are there any serious ways to test synchronization?
            #23787
            Steo
              Try powering on the SNES and unplug the HDMI cable from the OSSC. If the light doesn’t turn green then it’s nothing to do with the TV.
              Cheap RGB cables are hit and miss. I had to buy them from retrogamingcables because mine were of poor quality and kept dropping sync also. The SNES is very fussy too and the SNES at 50Hz doesn’t even work on my TV at all iirc.
              #23792
              Vincenzo213
                the no sync is of 1 second never more.
                #23793
                Vincenzo213
                  the problems are also present when the television is off (my weekend is great …)
                  #23794
                  Steo
                    If you haven’t already you should default the settings just to rule that out too. Stuff like analog sync LPF can affect the synchronisation too.
                    #23800
                    Vincenzo213
                      no change, I have an image with each console and always the same problem
                      #23802
                        Where did you get your SCART cables from?
                        #23804
                        Vincenzo213
                          official for dreamcast gc / snes, ebay for others
                          #23807
                          Vincenzo213
                            So I just tested the neogeo in passthrough and there is no disconnection in red led, for example with the other modes every time I press a button to quickly move from the logo to the menu I have the right to a few disconnection moments but not in passthrough. I have disconnections but the LED is green. I try to play sync but for the moment no results.
