Ossc problems or problemw is my samsung tv?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Ossc problems or problemw is my samsung tv?
- This topic has 16 replies, 5 voices, and was last updated July 8, 2019 at 6:10 PM by
bamf226.
July 7, 2019 at 10:33 AM #26931
Ho guys,recently i bought the ossc but i got some problem with my old console.
If i try ti connect the with scart i got two different output .
The first one is av black and white with no sound and the other is green .
With rgb Connections no video and only audio.
The firmware is the latest release.
I dunno if is a compatibilty issue or ossc problems
Can someone could give me some help ?
Thank in adviceJuly 7, 2019 at 10:36 AM #26932Forget another info:
My samsung is model ue40ku6400uxzt
ThanksJuly 7, 2019 at 12:14 PM #26935Which consoles, which RGB cable and what does the LCD on the OSSC say when you connect them?
July 7, 2019 at 12:25 PM #26936Console are :Nes , n64
When i start ossc the first view is palette green scale configuration
The rgb is the n64 rgb with cable or with rgb adapterJuly 7, 2019 at 3:41 PM #26938The OSSC is only compatible with RGB and YPbPr sources, and neither the NES nor the N64 natively output RGB. Have you installed RGB mods in your NES and/or N64?
July 7, 2019 at 4:02 PM #26940I got rgb adatapter includesse in console and red with e and yellow cable no mods
July 7, 2019 at 4:04 PM #26941July 7, 2019 at 7:08 PM #26943That’s a composite cable, not an RGB cable.
If you want to use the OSSC, you need to mod both consoles to be able to output RGB.
If you want an easier solution that accepts composite from those two consoles, you should get the Retrotink2X instead, and return the OSSC.July 7, 2019 at 7:11 PM #26944Ok
Thanks so if this is the perfect analisys of the situation and there are no other Solutions , i return the ossc :/
Thanks for you replyJuly 7, 2019 at 7:21 PM #26945But on you tube i see this video where i guy sue composite cable or i wrong
July 7, 2019 at 8:10 PM #26948I didn’t see any composite video cables in that video. He’s using component video cables, specifically HD Retrovision’s Genesis and SNES cables, which take the native RGB output from those consoles and converts it to YPbPr.
The NES only outputs composite video at best, and the N64 only outputs S-Video at best; so HD Retrovision’s cables won’t work for you. You’d need to do one of the following:
A. Install RGB mods and get the correct cables;
B. Get a RetroTINK 2X, which you can either connect directly to your HDMI TV or pair with an HDMI->VGA converter to connect it to the OSSC; or
C. Get a Koryuu (whenever they get released) or another composite video/S-Video to YPbPr component converter, which you can connect to the component video input on the OSSC as shown in the video you linked.You can, of course, just get a cheap converters on Amazon, eBay, or AliExpress–like a composite video/S-Video to SCART converter if you want to keep using the OSSC, or a composite video/S-Video to HDMI converter if you want to connect directly to your TV–but they won’t be without their problems, such as added input lag, black crush, poor color conversion, and/or questionable scaling methods.
July 8, 2019 at 7:13 AM #26953Hi ,
Thanks for your reply
You mean sonething like that :
VTOP Adattatore Scart SVHS S-Video, S-VHS da AV 3 RCA Maschio a Scart Femmina a Uscita in Linea https://www.amazon.it/dp/B01CV4MN7K/ref=cm_sw_r_cp_api_i_64TiDbK1EP9W8July 8, 2019 at 11:50 AM #26959No it won’t work, it doesn’t convert the signal to RGB/YPbPr.
I don’t understand what nmalinoski means with his suggestion, because such a cheap converter does not exist afaik. That’s the whole point of the upcoming Koryuu converter.July 8, 2019 at 12:27 PM #26960Hi
Please could you link some of rhis converter ?
Thanks
July 8, 2019 at 3:12 PM #26961I was suggesting pairing a composite to HDMI converter with an HDMI to VGA converter in order to effectively get composite video into the OSSC; but, like I said, it’s not going to be a perfect solution, because that composite to HDMI converter will likely treat 240p as 480i, it will add at least a frame of lag, and, since it’s composite video, it’s still going to look like garbage.
