OSSC Profiles for PAL users
Viewing 10 posts - 16 through 25 (of 25 total)
  • #48387
    Opaque79
      It’s possible that your TV will not accept the signal from the profiles. They won’t work on all displays.
      #48388
      Ruud85
        But then it’s still weird that on the settings that do work my everdrive doesn’t
        #48389
        Opaque79
          Ah. Sorry, I can’t help there, never used an everdrive.
          #48454
          Opaque79
            New info.
            As you may have seen, these profiles cut off some of the image in PAL games. If the loss of images bothers you, increase the V. Active to any value between 240 and 288. Some of you may have known this already. Not sure if it gives any extra sharpness though.
            EDIT: Of course, it will depend on your display whether this works.
            #48612
            Opaque79
              However, I am a little concerned recommending that as I believe forcing a 1600×1440 image can damage the TV but I guess it would be just the same as generic 4x mode displaying a 1280×1152 image?
              #51910
              feixlweixl
                Thank you for the profiles!
                I wondered if someone has created some PAL profiles and boom, here I am 🙂
                I’m about to test things out, play a little with the phase in a N64 test suite and then I’ll report back.
                Thanks again and all the best,
                Felix
                #52430
                asdddsa
                  Hello, I wanted to connect an old PAL 4: 3 576i video camera, but using the above “Generic 4:3” profile resulted in the image being displayed in the 16: 9 aspect ratio – the image was stretched. I have read a bit about the PAL signal itself in the book “Video Demystified A Handbook for the Digital Engineer 4th ed – Keith Jack” and you can find a solution there based on the graph analysis on page 48.
                  We know, from 576i graph mentionet above, that 576i has 720 active horizontal samples (h_active), for 4:3 ratio total samples (h_total) will be:
                  h_total = h_active / 0,75
                  h_synclen = h_active * 0,0904716073147257
                  h_backporch = h_active * 0,0890625
                  v_active = 270
                  v_backporch = 312 – v_active – 14
                  So:
                  h_total : 960
                  h_active : 720
                  h_synclen : 65
                  h_backporch : 86
                  v_active : 270
                  v_backporch : 28
                  It works perfect 🙂
                  #53321
                  Opaque79
                    Some minor tweaks made to the profiles and are updated for firmware version 0.89. I should probably give a reminder that the “PAL” profile is just a default profile with compatibility tweaks for problematic displays. The rest are for various consoles.
                    Hope people are still finding these useful
                    #58324
                    DiabboVerdde
                      hey @Opaque79, did you create all these profiles from scratch or did you base yourself in NTSC profiles? if you did use NTSC profiles as base, what would be the first things to modify on an NTSC profile to make it PAL? at least as a starting point of course, then tweak it until it gets perfect.
                      I’m asking because i’m trying to create a PAL profile for the Neo Geo, and your PAL profiles worked really well for me, so I want to follow the same methodology you used.
                      • This reply was modified 2 years, 1 month ago by DiabboVerdde.
                      #58326
                      Opaque79
                        I think I did them from scratch but this site helped out a bit
                        https://junkerhq.net/xrgb/index.php/Optimal_timings
                        The sample rates weren’t much different to NTSC though some console do need a different sample rate. If a PAL Neo Geo fits the 240P or 224p image in the PAL frame, the sample rate may be the same as NTSC but I would just try and eye ball it. If you have the 240p Test Suite for the Neo Geo, you can use the checkerboard pattern to dial it in as FireBrandX demonstrated in his tutorial video
