OSSC remote question on “select OSSC mode”
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC remote question on “select OSSC mode”
  • #40288
    Fugazi70
      What does the button “Select OSSC Mode” do on the remote?
      #40289
        The remote can control three separate devices, and the commands for the OSSC are programmed only into its TV mode.
        So that button simply switches back to controlling the OSSC in case you’ve switched the remote into the DVB or HiFi modes.
        #40291
        Fugazi70
          Thanks I was programming my harmony hub remote and wasn’t sure what it did
