OSSC scanning wrong resolution?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC scanning wrong resolution?
  • #23125
    Spitko
      First off, as I’ve seen it in other threads, this isn’t about the number OSSC’s LCD shows. This is about the actual image. Note the example below, letters in certain columns look particularly bad, but most show some signs of being sampled off-target. These fonts should all be pixel perfect, with no alpha channel.
      Not sure what to make of this honestly. It looks like it’s trying to do some kind of crazy linear interp across the screen; which implies to me it’s sampling pixels at the wrong resolution. I tried adjusting the sampling phase, but it just “moves” which pixels are sampled wrong. Nothing seems to correct the core problem.
      System resolution: 512×512 ( Sharp X68030 )
      OSSC reports 568p @ 31.5kHz / 55.46Hz
      Sample2x OFF
      Line2x ON
      Tried resetting to default as well
      #23127
        You should set upsample2x to ON, it will then sample at double resolution horizontally.
        #23128
        Spitko
          That does appear to fix the issue, is that simply necessary for x68k? The documentation seems to imply the default (off) would produce a 1:1 representation of the source image.
          #23129
          paulb_nl
            With 568 lines the OSSC will choose the X68k 640×512 resolution at 800 samplerate. For pixel perfect sampling of 512×512 you have to change the sample rate at the advanced timing tweaker and adjust sampling phase.
            It will be easier if you can get it to display a checkerboard pattern.
