OSSC + SNES Artifacts
- This topic has 3 replies, 3 voices, and was last updated June 14, 2019 at 8:18 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC + SNES Artifacts
Hello,
I finally received my OSSC and I have issue with some artifacts on solid surfaces (grass/sky) like in picture.
What Could be the reason? I am waiting for good quality rgb cables.
Apart from that my Sony Tv tells me that provided signal is not supported apart from x2 multiplication. Even passthrough doesnt work.
IS there anything I can change / manipulate to push “supported” signal to TV? Or should I buy monitor?
Thanks!
That looks really bad. Definitely test it once you get a high quality RGB cable.
Did you purchase the OSSC from VideoGamePerfection, or another site like AliExpress?
Pretty sure image will clean up nicely with better cable.
A lot of Sony TVs, especially W-series, will not accept anything besides 2x mode. Check the TV compatibility thread and tweaks thread for more info if you are looking for other models/brands.
Hello,
Thanks!
This is original one from VGP. I am totally against anything from Aliexpress.
