OSSC + SNES dejitter mod +Sony 4K = Success!
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC + SNES dejitter mod +Sony 4K = Success!
- This topic has 11 replies, 5 voices, and was last updated January 5, 2019 at 7:55 PM by
Ruud85.
January 2, 2019 at 9:05 PM #24561
I finally got my SNES (Japanese Super Famicom) working on my Sony 4K TV
<img src="<img src=”https://i.ibb.co/6BDsvrr/IMG-0014.jpg” alt=”IMG-0014″ border=”0″ />” alt=”OSSC on Sony 4K” />It was a right pain but here are my settings in case anyone else has a sony 4k + SNES
I did the de jitter mod and that helped but still kept loosing sync so not 100% sure if its needed without removing it (and i aint going to do that)
Video LPF 16Mhz
HPLL2x=off
upsample2x=onadvanced 256×240 timing
v synclean=3
v backporch=14analog sync LPF=off
analog sync Vth=146mv
hsync tolerance=8.00
vsync threshold=11.84
H-PLL pre cost=2 lines
H-PLL post cost=2 lines240p/288p proc=Line 5x
Line 5x mode=256×240 optim
Line 5x format=1920×1080
256×240 aspect=8:7
tx mode = HDMI
HDMI ITC=Onscanlines=auto
reverse lfp=3full tx setup=off
av3 interlacefix=offJanuary 4, 2019 at 2:05 PM #24601I can’t wait to send my pal 60hz modded 1 chip snes for a de jitter mod so I can also play 16% faster
I tried your setting but It ain’t working without the mod
Al of sudden I don’t have sound anymore
When I change the setting to factory it still won’t come backCan someone tell me what to do please
January 5, 2019 at 12:14 PM #24608@mistasparkaru You probably don’t have the mod wired properly for your RGB cable (c-sync, sync on luma or composite?). If that is the case, H-PLL post cost=2 lines would be a workaround for the wiring issue.
January 5, 2019 at 1:09 PM #24610It was working fine before so don’t think it’s the wiring
I thought I set something wrong in the ossc but when I reset the settings to stock I still don’t have any sound
I’m gonna order a super nt today
Saw Verry good reviewsI think it’s just a bit lame the ossc don’t support snes properly and also hooking up a Nes and n64 is a problem
Mebe when the de-jitter mod is back in stock I will give it another go
Until that time I can play on the super ntJanuary 5, 2019 at 3:48 PM #24612If you are still using the OSSC test firmware then you won’t have sound.
January 5, 2019 at 3:52 PM #24613Ah ok so that’s the sound problem
So I just need to reinstall the latest firmware version then?January 5, 2019 at 4:36 PM #24614I did a firmware update install 0.82
Still no sound:-(
Everything else works (on 50hz)
Also my ps2 with rgb cable has no soundWhy is this all so complicated
January 5, 2019 at 5:07 PM #24615I just tried another TV and it’s the same problem
No soundBut when I plug my snes rgb cable in tv it does give me sound
Is my ossc broken ?
January 5, 2019 at 5:14 PM #24616Did you install 0.82 or 0.82-aud? Firmwares with the -aud suffix are the ones with audio support.
January 5, 2019 at 5:40 PM #24617Yes thx i have sound again
I got the wrong one installedNow it’s waiting for the de jitter mod getting back in stock
January 5, 2019 at 7:35 PM #24619Looks currently in stock to me.
January 5, 2019 at 7:55 PM #24620Snes de-jitter instalation service
When I click this it says item not in stock
Also I send a direct email and they were saying it will come back in 2019
So I just have to wait until I see its back available
Also I want to let my pal n64 modded so I can use rgb with that to
But I wonder if when I use a scart splitter and hook up rgb cables of my snes n64 and ps2 if they al run on the same settings as the snes takes a lot of adjustment in the ossc
