OSSC with Raspberry Pi
  • #16147
    allsyntax
      Total beginner question – but would it make any sense to try to use this device with a raspberry pi game emulator? I understand inputs are limited, but perhaps with a HDMI to SCART connection?
      #16148
        I don’t think it makes any sense to use an OSSC with a RasPi.
        The purpose of the OSSC is to digitize and line-double/-triple/etc. the low-resolution, analog video signals of (primarily) old game consoles that newer TVs can’t handle for one reason or another–lack of appropriate analog inputs or 240p support over HDMI on the TV, and/or lack of HDMI support on the console.
        The RasPi boards all come with digital video output over HDMI, so they don’t have the problem that the OSSC is intended to solve; not to mention you’d be spending an extra ~$250USD’s worth of equipment to degrade your signal by converting from digital to analog and back to digital. :/
        #16149
        allsyntax
          Fair enough. I suppose I was thinking about scanlines.
          #16191
            I would expect the emulators to be able to provide scanline generation. Which emulator(s) are you using?
            #16224
            allsyntax
              Mednafen. Thought it might be a dumb question, thanks.
              #16275
              oscartilheiro
                yes make sense because the quality and easy of use that ossc gives (its great) and because some mame games get slow with good scanlines. I tried arcadevga 5000 with ossc and didnt work. Now i am thinking in raspberry pi
                #16290
                oscartilheiro
                  Other thing you change scanlines the same way all the emulators just put up and down in your remote controller
