output sync polarity option
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Feature Requests output sync polarity option
  • #11740
    goombas
      Hi there,
      Would it be possible to have a setting that sets the output v-sync/h-sync polarity (Pos/Neg/Pass Through)?
      My capture card won’t work unless this is set correctly.
      By the way, plugging a Genesis II to a TV via the OSSC and the XRGB mini, the later initially shows a negative v-sync/h-sync input on the status page but switch to a positive v-sync/h-sync as soon as I change a video setting on the OSSC, like going from Line2x to Line3x. I have to reboot the OSSC to restore the negative polarity.
      Might be a bug on the framemeister but could you explain the default OSSC behavior?
      Thx.
      #11876
        OSSC currently always outputs at negative H&V polarity. It should be possible to add an option for custom polarity once the sync generation code is cleaned up a bit.
        #11882
          Hmm, very interesting, I see from some TV manuals and CEA spec sheet that most resolutions above 480p use positive sync polarity. Will be very interesting to see if this contributes to display incompatibilites…
          #11895
          goombas
            Ok, thanks for the info.
            I retried my test the other way around: after 3 reboots of the framemeister without touching the OSSC, the status page switched from NEG/NEG to POS/POS.
            I conclude that there is a glitch on the framemeister side.
