PC VGA + sound card audio to HDMI?
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › PC VGA + sound card audio to HDMI?
  • #44949
    edlin
      Hi! I am using the OSSC to connect an old PC to a modern HDMI display, and I have a question about the AV3 VGA and audio inputs.
      My understanding is that if I connect both the VGA and sound card (stereo) line output of my PC, the OSSC will reroute everything through HDMI, so I should get both video and (stereo) audio on my HDMI display. Is this correct?
      Thus far I was able to get the VGA output on my HDMI display, but no sound. Before insisting, I’d like to be sure that this is supposed to work 🙂
      Thanks!
      #44988
        Yes that’s correct, make sure you’re connecting to the AV3 audio in and not AV1/2 connector.
